show slpp guard
show slpp guard {ports port_list} {disabled-ports}
Description
Shows Simple Loop Protection Protocol (SLPP) Guard status for selected ports or all SLPP Guard-disabled ports.
Syntax Description
slpp Specifies configuring SLPP.
guard Specifies disabling a port as soon as an SLPP PDU is received.
ports Specifies selecting ports that you want to see SLPP Guard status on.
port_list Selects the ports that you want to see SLPP Guard status on.
disabled-ports Specifies showing information about ports disabled by SLPP Guard.
Default
N/A.
Usage Guidelines
SLPP is an application that detects loops in a Split Multi-link Trunking (SMLT) network. SLPP Guard is a complementary feature that helps prevent loops in networks by administratively disabling an edge port if a switch receives an SLPP PDU from an SMLT network.
This command shows SLPP Guard status about selected ports (ports option) or shows all ports that have been disabled by SLPP Guard (disabled-ports option).
The following example shows SLPP guard status for ports 15, 16, 31, 61, and 62
# show slpp guard ports 15 16 31 61 62
Port       SLPP Guard  State       Timeout     Age  Last Time Disabled
15         Enabled     Disabled        300      46  Thu May 17 12:30:27 2018
16         Enabled     Monitoring      300      NA  NA
31         Enabled     Disabled        300     218  Thu May 17 12:10:27 2018
61         Enabled     Disabled        300     205  Thu May 17 12:20:27 2018
62         Enabled     Disabled       None      NA  Thu May 17 12:35:27 2018
State:
    Disabled:    Port disabled due to SLPP PDU received.
    Monitoring:  Listening for SLPP PDU.
    None:        Port is down.
SLPP Guard Ethertype   : 0xefef
The following example shows SLPP Guard-disabled ports:
# show slpp guard disabled-ports
The following example shows SLPP Guard enabled by CLI:
        Enable
Port       SLPP Guard  State      Timeout    Age Last Time Disabled      Flags
1          Enabled     None            60     NA NA                      C-
State:
         None:        Port is down.
Enable Flags: (C) By CLI, (R) By Radius VSA
SLPP Guard Ethertype: 0X8102
The following example shows SLPP Guard enabled by Radius VSA:
        Enable
1          Enabled     None            60     NA NA                      -R
State:
         None:        Port is down.
The following example shows SLPP Guard enabled by Radius VSA and CLI:
        Enable
1          Enabled     None            60     NA NA                      CR
State:
         None:        Port is down.
This command was first available in ExtremeXOS 30.2.
Support for the Radius Attribute was introduced in ExtremeXOS 31.4.
Platform Availability
